Luke,
Since your project is a 14 volt system, use the ratings listed for the 115 volt AC. These ratings are VERY close the the 14 volt ratings.
FYI, each cell in a common wet cell battery generates 2.2 volts. 6 cells multiplied by 2.2 = 13.2 volts. Add a slight (0.4 to 1.4) voltage increase to charge the battery and you see that it should be called a 14 volt system.
You should buy a copy of Bob Nuckholls excellent book on aircraft electrical systems THE AEROELECTRIC CONNECTION 12th Edition. You can order it below. It will answer nearly every question you have regarding your electrical system. See
https://matronics.com/aeroelectric/C...ECcatalog.html
Charlie Kuss
