Aerobatic breather fitting inside engine ?
Hi, I could be way of base but I've never heard anyone on VAF mention anything on the inside of the engine to help min. oil loss out the breather tube during aerobatics. I know on the continental engine for aerobatics there is a 90 degree fitting on the inside so when the oil migrates to the side of the case very little [or less] gets out of the engine. if there is no 90 degree fitting all the oil that slides by the opening goes out, if you have a 90 degree fitting most goes right pass. Doesn't Lycoming have the same option for a fitting at that opening. And if not couldn't you tread that opening and put one in anyways? just want to throw this out and see what you guys with Lycoming know how, know or think about this. Gene
Gene Bumgarner RV-7 Emp./wings
