05-07-2009, 09:12 PM
RV-7 Tail vs 8
Just wondering, what are the differences between the -7 and -8 tails? Could you use the 7 on an 8 and vise versa?
05-07-2009, 09:47 PM
yes you can
The RV-8 rudder use to be the same as the RV-7, but they went to the larger one I think back in '02 (which I believe is the same as the RV-9 rudder?). You can definitely use the newer RV-7 rudder on the 8 (100% sure because I have chatted with Van's on this and am doing it on my 8). Dave
05-08-2009, 05:34 AM
Just wondering, why? Is there a reason, or is it just what you have? I am just asking, not judging.
Thanks, Lance
RV-8 108LF
05-08-2009, 06:23 AM
the skins on the horizontal are different because of the narrower fuse on the -8
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
05-08-2009, 06:38 AM
We've measured my -8 rudder against my buddy's -7rudder, and his is larger in all dimensions. The benefit would be more rudder control, I believe, which would be desirable in a tailwheel acft. Just my .02 cents worth.
Jim Brown
RV6, Christen Eagle II(Sold)
ATP, CFII, A-IGI, A&P/IA
Carrollton, GA
Lyon?s Landing
05-08-2009, 07:23 AM
Why
The main reason I am using the larger 7 rudder on the 8 is because I built the 8 rudder with a trim tab on it (kind of large). The more I looked at it, the more I wanted a "clean, non trim tab tail." A buddy had a 7 tail that Vans sent him (to replace his older smaller one) and he said he wasn't going to use it, so he gave it to me. Makes sense to me to have a little bigger rudder for more control, so what the heck? That's the only reason -- can't say it was fully planned or anything. Dave
05-08-2009, 07:37 AM
Dave,
Not to hijack this thread--but did you build that -8 rudder trim tab "on" or "in" the rudder? If you cut it into the rudder, I sure would like to see any pictures you have. Pls PM me if that's the case.
Jarvis
Purchased flying RV-7A
RV-7A emp finished, wings next.
05-08-2009, 07:38 AM
For crosswind control, the two different tails are mostly a "wash". Even though the larger rudder gives you more rudder authority, the extra area also increases weather vane tendencies, causing you to need more authority.
The larger rudder was primarily designed to aid in spin recovery.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
05-08-2009, 08:38 AM
Thanks, Lance
Not particular reason, just my own wondering. I knew that the 7 and 9 shared a lot of common parts, I wanted to know about the 7 vs 8.
05-08-2009, 07:26 PM
pic
Jarvis. email has been sent w/pic. Dave
