I have float senders mounted in the 2nd bay (flop tubes) and got all the wire and connectors. Im just trying to figure out which the best route would be as far as routing. I cant wait to do this because once the wing is on, I will not have access to the sender. Here are the options I have thought of:
1. Drill an 11/32 hole through each Z bracket for gromets to pass the wire through (I have some groments that are 11/32 OD, 1/8 ID, which is bigger than the wire (20g) but its all I could find... does the wire have to be snug inside the gromet?)
2. Drill the same size hole through the web then bring it to the root end...
Option 1 seems to be the best to me, but I dont want to drill holes that aren't in the plans without asking here first.
Any body have any other ideas or input?
Here is what I had in mind (and yes I know the flag is backwards in this pic, its been fixed
