Old 05-06-2009, 07:01 PM
avee8tor13 avee8tor13 is offline
Default has anyone wire tied fuel line fittings?
I noticed on some of my fuel lines there was a hole drilled in the fitting, almost as if to be a starting hole to drill partially through the fitting and then wire tied. Any thoughts folks?
Old 05-06-2009, 07:20 PM
G-force's Avatar
G-force G-force is offline
Is it a hose end for braided line? If so, look close at that hole, usualy is has had an aluminum wire pressed in there and that is the retainer to hold the assembly together. Typicaly you only see these on swivel fittings. This may (or may not) be what your seeing.
Mike Sumner
Castaic, Ca
Old 05-06-2009, 07:58 PM
asav8tor asav8tor is offline
I do; Belt and suspenders type of guy.
