Old 11-28-2005, 05:46 PM
Gsuit's Avatar
Gsuit Gsuit is offline
Default Safety wire Technique
I posted a message somewhat like this one on the Yahoo! RV forum, so if you've read it - disregard this one (or vice-versa )
I'm generally Ok with safetywiring things, but safetywiring the electric aileron trim bias spring to the control column tab is killing me!!! How do you safetywire twist something on both ends?!?! If you need further details, reference drawing OP-19 Completed Assembly Iso View that comes with the electric aileron install kit.
Any advice would be welcome!
Clayton Henderson
Beaumont, TX
RV-7 N454CH (Flying)
Old 11-28-2005, 06:48 PM
vlittle's Avatar
vlittle vlittle is offline
Default aileron trim safety wiring
Near the bottom on this page is my photo of how I did it. Kind of obvious once you see a photo.
http://www3.telus.net/aviation/flyin...age_photos.htm
Good luck
Vern Little
Old 11-29-2005, 05:37 PM
Gsuit's Avatar
Default Thanks!!!
Vern, you 'ole rascal! That's it. I figured it was something simple... but, I was totally "wrapped around the axle" in capturing both ends in one loop.
Thanks a ton!! I guess I'm buying the next time I see you
Clayton Henderson
Beaumont, TX
Old 12-27-2005, 01:15 PM
I'm at this point and my eyes are failing me. I'm not sure what the procedure used for this was. How 'bout a narrative?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 12-27-2005, 06:53 PM
vlittle's Avatar
Better yet, how 'bout a poem?
Take your wire, loop it through
The spring end (that'll do)
Clamp your pliers 'bout one inch along
Pull the end and twist it strong
Loop through the doodad with the hole
Clamp your pliers and give it a pull
Fold the end and give it a trim
For other side, do it again!
Vern
Old 12-29-2005, 02:36 PM
Well it take 3 or 4 tries, Vern, but it came out fine thanks to your poem. I'm glad the question wasn't about hanging an engine from Mattituck.
Bob Collins
St. Paul, MN.
Old 03-23-2006, 07:57 PM
jlfernan's Avatar
jlfernan jlfernan is offline
What's the difference between a $75 pair of safetywire pliers and one for $20, besides $55.00? Are a reversible pair crucial?
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 03-23-2006, 10:16 PM
Jekyll Jekyll is offline
Naw, just buy 2 $20 pairs for $40 total. The only catch is that you must specify you want one set for Northern Hemisphere wiring and one set for Southern Hemisphere wiring (you never know when the coriolis effect will make itself known, aviation mechanics must keep in tune with this just as do pilots).
Maybe one of our great OZ friends would be willing to lend you a pair of theirs for a while.
I guess you could just wing it and stand with your back to the work and push on the handle.
Hey, I just saved you any where from $20 to $55, will you buy me a beer?
Jekyll
Old 03-25-2006, 04:46 PM
Jorge:
A serious answer:
I was a military helicopter mechanic for a number of years on 1960 vintage designs which are basically held together with about 500 lbs of safety wire in all sizes. Many applications were in some pretty amazing locations that required rubber arms and fingers to reach. Try wiring up swashplate bolts some day. Safety wiring was something I did 100 times a day and a well dressed mechanic always had a pair of swaps in his back pocket. I never used a set of reversable swaps and don't think I missed them. The limited amout of reverse twisting is easy to accomplish by simply hand rotating the swaps.
RV's use very little safety wire and the added expense of reversable swaps is better used on your panel (IMPO).
Jekyll
Old 03-25-2006, 08:54 PM
Harvey's Avatar
Harvey Harvey is offline
Location: I live on an airpark in South East Queensland, Australia
Down here in Oz we just use plain old Left Handed wire-twisters....
Martin in Oz
