Old 05-05-2009, 01:34 PM
Tumper's Avatar
Tumper Tumper is offline
Default Tip: Another idea for dimpling in tight spaces
I needed to squeeze some dimples in a tight space this past weekend and I didn’t want to wait to order a new tool so I came up with something that maybe someone else can use. I started with a pull rivet dimple set I had in my arsenal of tools, and added a pair of vise grip pliers (available at your local aircraft supply store, Lowe’s).
I used an angle grinder with a $2.00 .045” thick DeWalt thin cutting wheel blade to cut a slot in the teeth of a pair of $8.00 - 10” vise grips. I also cut out the top of the jaw on one side of the vise grips to allow the head into a smaller area.
As the picture shows the nail normally used to pull the dies of the dimple set together now only hold the dies in position until the vise grip pliers squeeze the dimple.
Not bad for the price, and it fit well into the tightest location in the rib of my RV-9 elevator (pictured).
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
Old 05-05-2009, 01:55 PM
WenEng WenEng is offline
Default I love VAF website because of..
ideas like yours. Simple and effective. Keep posting more..
Thanks.
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
Old 05-05-2009, 02:36 PM
JHines JHines is offline
Default I did the same thing...
Except I drilled holes through the jaws to accept the shanks of regular dimple dies. Your method would appear to involve much less cursing and dull drill bits.
Jonathan Hines
Charlotte, NC
Old 05-06-2009, 06:34 AM
Tomcat RV4 Tomcat RV4 is offline
Default die holder
What another great idea.....I did a similar thing with large pair of channel
lock pliers for reaching in 2" from edge.........Tom
Old 05-06-2009, 06:37 AM
rocketbob's Avatar
Easy answer....get some carbide drills.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 05-06-2009, 06:53 AM
Rupester Rupester is offline
Great idea !! Thanks for sharing.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 05-06-2009, 07:06 PM
BSwayze's Avatar
BSwayze BSwayze is offline
Default I did a similar thing, too...
Great idea! Thanks for posting it!
Instead of carving up a pair of vice grips, I cut the nail very short. It's only use was to hold the two dimple die halves in place through the hole in the rib. Then I could get a thin-nose yoke in there and use my rivet squeezer to squeeze the dimple. My thinking is, the rivet squeezer can develop more squeezing pressure than the vice grips. In any case, I found that cleaning up the dimple a bit with my deburring or countersink bit removed very little metal but left a very nice dimple.
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 05-07-2009, 05:43 AM
SmittysRV's Avatar
SmittysRV SmittysRV is offline
Great idea Dean. Keep em' coming!
Smitty
Old 05-09-2009, 10:30 PM
Experimental Chaos's Avatar
Experimental Chaos Experimental Chaos is offline
Default Here?s another method
The method that has always worked for me, was to take a piece of ? or 3/16 flat steel bar stock, and drill and counter sink a hole near the end. Put the steel flat stock in a vice and use rod that comes with your C-frame dimpler and a male dimple die, all loaded into your rivet gun, use the steel flat bar for the female die, and a couple of rattles with the rivet gun and you have a perfect dimple. I think it helps to hit the home made female dimple die with a scotch bright wheel, and you must be careful to keep the rivet gun straight, or you risk breaking the guide pin on the male dimple die. I?ve done this for years and only broken one die. Of course practice on a piece of scrap.
Mike Mason
Fairfield/Vacaville, CA
RV-7 QB Working on Wings, Fuselage & Sanity
VAF 1351
AOPA 04067557
EAA 837577
mgmason1911@gmail.com
