Superior sump throttle bracket bolts
I have the newer Superior sump (was a replacement from the recall). I am going to put a mixture and throttle bracket on the bottom towards the front where the two holes are on each side. A 1/4"-28 bolt won't fit, and a 1/4"-20 seems too loose (though not by much). Does anybody recall what size bolts they used? Thank you. Dave
