Old 05-04-2009, 10:42 AM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Default mounting headset plugs
How should I mount the headset plugs? I don't have any instructions, and I can't find anything on the 'net or archives here. I have plastic shoulder washers, thinner rigid plastic washers, and some metal washers that came with my kit. I'm guessing the order of things from top to bottom would be:
  • nut
  • metal washer
  • rigid plastic washer
  • airframe
  • plastic shoulder washer (pointed "up" sitting in the airframe hole)
  • plug
Probably a dumb question, but I'm feeling dumb today.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 05-04-2009, 11:27 AM
DGlaeser DGlaeser is offline
Default sounds good...
The lip of the plastic shoulder washer should point toward the plastic washer. As long as the plug body doesn't touch the airframe, you are good to go...
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 05-04-2009, 01:57 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default mic/phone jack locations
I mounted mine in the "arm rest" so as to keep headset cords off my lap. That "T" washer is to keep the jack stack electrically insulated from the mounting penetration. The arm rest thickness works perfect with that washer.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 05-04-2009, 02:04 PM
ao.frog ao.frog is offline
Default Check the drawing.
Hi.
I bought my intercom and radio from Vans and there was a drawing included in that package.
If you like, I can scan a coulpe of pages and send you from the Vans DWG. They are pretty good.
By the way: I mounted mine on beetween the seats on the bar which the seatback "lean on" and I'm very happy with the loaction.
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 05-04-2009, 02:51 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Check out this link also http://www.aeroelectric.com/articles...k/micjack.html
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
