Old 11-28-2005, 09:38 AM
jferraro17's Avatar
jferraro17 jferraro17 is offline
Opulence, I has it...
Default Rudder leading edge -- need advice.
Guys--
I've rolled my Rudders leading edge, the top and bottom sections worked out nicely, the middle section, not so much. I managed to re-roll a bit, and get it together without so much "forcing", but the lap joint is really wavey, or puckered between the rivets.
Any suggestions? More rivets between each (spacing issues)? Tap with a hammer/work the edge?
Anybody out there recovered from this?
Thanks--
Joe
Joe Ferraro
DFW, VAF #17
SOLD
Old 11-28-2005, 09:53 AM
AndrewTR30 AndrewTR30 is offline
Default Try using an edge rolling tool.
It helps one skin lay down flat on the other. You don't have to put a lot of bend in the skin. Just use light pressure to roll a little crease into the edge of the outer skin.
Andrew Rayhill
RV-10 40078
Phoenix
Old 11-28-2005, 10:37 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by jferraro16
Guys--...the top and bottom sections worked out nicely, the middle section, not so much. I managed to re-roll a bit, and get it together without so much "forcing", but the lap joint is really wavey, or puckered between the rivets. Any suggestions? More rivets between each (spacing issues)? Tap with a hammer/work the edge?Anybody out there recovered from this?Thanks--Joe
Hi Joe,
I am sure you are aware (though not relevant to the rudder) but (for moisture shedding purposes) the elevator top skin will overlap the bottom skin....this applies later on. But the joint is the same. Beyond that, keep in mind that joint will not show. No one will ever know it but you. Still, I ran into a similiar situation during my -8A empennage work and was not happy with the overall quality of the finished lap joint. Going against the written caution in the instructions, I went ahead and drilled out the blind rivets. (Van assumes the average builder will have trouble drilling out those rivets). I then rerolled/massaged/reworked the skins and used an edge rolling tool on BOTH skins much as you would with any overlapping (or butt adjoining) skins. The final result was a significant, though not perfect improvement over the first effort. Since there is plenty of space between those pull rivets, you can easily lay out 1 or 2 additional holes between the plans callout spacing and add more fasteners if you want to. Most folks would settle to just leave well enough alone. The choice is yours and yours alone to make.
Rick Galati RV-6A "Darla"
RV-8A empennage complete
Old 11-28-2005, 10:49 AM
jferraro17's Avatar
Default Thanks Rick!
I too drilled out the first set of rivets...all of them. (didn't find them any more difficult than solid ones, lot's of practice I guess ).
I think I'm leaning towards one rivet between each pre-punched...I'm concerned about the tension on the heads, as well as the moisture issue and looks--the top and bottom protion of the leading edge came out so nice, I don't think I can stand leaving the center section so cheesy!
Thanks for the advice.
Joe
Joe Ferraro
DFW, VAF #17
SOLD
Old 11-28-2005, 10:53 AM
jferraro17's Avatar
Default Edge rolling tool...
Andrew--
Funny thing is, the center section is the only one I bent with an edge rolling tool, and it's the only one with this problem. Maybe I put too much bend in?
Anyway, I'm going to have to practice with that tool before I use it again on the elevators.
Thanks for the suggestion--
Joe
Joe Ferraro
DFW, VAF #17
SOLD
Old 11-28-2005, 10:57 AM
mburch's Avatar
mburch mburch is offline
For what it's worth, I wasn't happy with the way my elevator leading edges were all puckered up, so I doubled up the number of rivets and they came out fine: click here for a photo. I think my bends could have been a little better, since I had to pull the two halves together slightly with my fingers, but there are a lot of fasteners and not much stress on them. As Van's says, I built on!
mcb
RV-7 QB parts arriving tomorrow
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 11-28-2005, 12:44 PM
jferraro17's Avatar
Default Thanks Matt--
We've got a spare bedroom we call the "airplane room" too!
Thanks for the sanity check...build on it is!
Joe
Joe Ferraro
DFW, VAF #17
SOLD
