Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #31
Old 02-02-2010, 06:29 AM
Bruce's Avatar
Bruce Bruce is offline
Default DAllas Area Balancing
Can anyone tell me who does this in the Dallas area.
Boomer
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 02-03-2010, 06:38 AM
Wallbangar's Avatar
Wallbangar Wallbangar is offline
Arrow BALANCE MY PROP
Anyone know of a good guy near Austin, Tx. with a balancer ???????
Old 02-07-2010, 07:49 AM
rcfaubion rcfaubion is offline
Default spinner on
Originally Posted by Captain Avgas View Post
Pat, are you saying that the balance was done with the spinner off. I would imagine that a spinner itself (and particularly a Vans spinner) could be considerably out of balance.
I think I'd want the balancing done with the spinner installed.
Just had my -4 done yesterday, left the spinner on and used the holes in the flywheel to attach weights (holes are spaced every 30 degrees). This worked great and now is very smooth!
Robert Faubion
Las Cruces, NM
N311SV RV-4 bought flying-instant fun!
SARL "Race 311"
Old 02-07-2010, 01:35 PM
Default question
D-B my prop at 2150 (max static rpm), what can I expect the balance to be when turning 2500=2600 in cruise? And how would you account for this if there is a noticeable change? Any thoughts would be appreciated.
Robert Faubion
Las Cruces, NM
SARL "Race 311"
Old 02-07-2010, 01:44 PM
mikegraycmg's Avatar
mikegraycmg mikegraycmg is offline
Default Byam
Byam Propeller at Meacham in Fort Worth is the main prop service in this part of the world. My recollection is that their balancing services are reasonably priced.
Mike Gray, A&P IA, AET, KGPM, Grand Prairie, Texas
1956 Bonanza for sale.
Old 02-07-2010, 03:01 PM
cguarino cguarino is offline
Default I'll rent you mine
I have a brand new Dyna Vibe balancer that I'll rent out (DFW) for $100 DIY. PM me.
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
Old 02-07-2010, 03:12 PM
Geico266's Avatar
Geico266 Geico266 is offline
Anyone in the Lincoln, NE area I do balancing for $150.
Have RV, will travel to your place.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 02-13-2010, 01:01 AM
rvmills's Avatar
rvmills rvmills is offline
Originally Posted by Bob Axsom View Post
As hard as it is to believe perhaps I have never had a prop dynamically balanced. Recently I replaced a Hartzell C/S with 7666 blades with one with F7496 blades. It is faster by 3 kts as advertized but it is noticeably roughter in vibration. After a few flights it seems fine and I'm interested in speed mainly but I'm thinking I may be able to get a fraction of a knot by getting the dynamic balance done at 2700+ rpm. Any experience in this in this frame of reference?
Bob Axsom
Originally Posted by rvmills View Post
Will let ya know what I hear from Eric at GSP.
Bob
Bob,
Sorry this took so long, but I finally talked with both Eric at Golden State Propellor, and John at American Air Racing. Both concurred that balancing at max RPM will not make you faster. In fact, given that you are running pretty smooth to start, a DB will probably have no perceptable impact on speed. Not sure if it would if you were running rough...unless you were a dern rattle-trap due to the prop...which of course you are not.
John explained that they do the DB at a mid-range RPM, one that "loads" the propellor (it's on the low-pitch stop, and creating thrust...thus bending forward a bit). He said if you went to a higher RPM, the prop would still be on the low pitch stop, and the increased thrust (bending moment) and speed/centifugal force would not make a significant difference in the dynamic balance...especially if the blades are well matched (they should be) and the prop was in good static balance. They both felt that the difference between 2300 RPM (for instance) and 2700 RPM would not be measurable. They both also chuckled when they said "and if you could keep the airplane on the ground...and find someone that was willing to stand in front of it!"
However, they both agreed that doing the DB will have a positive impact on the overall smoothness (albeit somewhat subjective). John added that even if your prop feels good now, a DB is well worth it, as there are vibes at frequencies you can't readily feel that may negatively impact the wear on the entire engine, engine mount, propellor system.
All FWIW of course...I personally think you'll get a knot or two out of it! And I wasn't paid to say that
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 02-13-2010, 01:41 AM
Default Thanks for the information Bob
Thanks for the information Bob I really appreciate your time and effort to get it and pass it along. I may do it at Hartzell some time in the future but not before the first race at Taylor, TX on 4-10-10. I fitted the second semi-flat wing tip yesterday and drilled the pilot mounting holes (#30). Some time today I will continue on with that effort. In the process I have been thinking of a way to cover the outboard aileron mounting brackets and associated openings. I still have to do the annual condition inspection so time is getting squeezed.
Bob Axsom
Old 02-13-2010, 11:56 AM
jlk jlk is offline
Default Placebo or science?
I have watched all the interest in dynamic balancing and I have had my Grumman Tiger balanced years ago, I am sure the equipment today is far superior to then.
What I bring up is the small weight differences in the balance process vs. the constant changes in the power systems of our planes. We use our planes. All props that are flown from pavement get stone dings. Metal props the dings are filed out and the prop touched up or repainted. We replace accessories, adjust timing and you get the idea do maintenance.
All these things change the balance of the rotating mass we call our engine and propeller. Constant speed props, the differential of the angle between blades while moving can cause changes in the vibration patterns; do we think our props move with absolute precision when changing pitch? Add to that, all this changes with RPM.
All this being said, I cannot see how balancing our power systems can have any long term affect, in the moment, at the rpm it was balanced, it is balanced. For how long and what about at other RPM. I propose that this is more placebo affect than actual science. You paid to have something done so you are invested in it, someone shows you a positive statistical result and you feel better about your plane.
I am not an engineer, I only try to present a logical arguement. I would like the engineering types to please put some more science in the discussion, one way or the other.
Jordan Kaplan
RV-7A
Just starting the journey
QB Fuse and Wings in the shop
