05-01-2009, 01:50 PM
Mag wiring...is this right? (Diagram pic incl.)
A picture is worth what?
Is the pigtail wire off the shield to common ground necessary? I've heard both ways...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
05-01-2009, 01:52 PM
No it's not needed..
Radomir
RV-7A sold
Remove the wire from the switch to FW ground block. Grounding all happens at the mag.
Scott Card
CMW E-Lift
05-01-2009, 01:56 PM
Thanks fellas!! So QUICK!
This would be correct then...
Chad Jensen
05-01-2009, 02:03 PM
YEP!
That'll do it. Just remember that the mag will be hot with the switch open. Close the switch to "kill" the mag.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
05-01-2009, 02:12 PM
Yep! Thanks Mel...I have the switch mounted upside-down.
Chad Jensen
05-01-2009, 02:24 PM
Chad, that's exactly how I did it. No pig tail and switch mounted upside down. No problems at all on this end.
You are moving right along, stay at it....it's worth it!!
05-01-2009, 04:44 PM
Chad,
There were some back and forth here a while back with people that do not endorse grounding the shield at the mag. (More prone to loosing a connection out there)
Either way will work, which is better? Iduno?
I plan to ground at the mag with a good pigtail from my P-lead shield. After all thats what mag checks are for right????
05-01-2009, 05:35 PM
The preferred method is to use the shield to ground at the mag. Otherwise you are just adding fail points to the system.
05-01-2009, 06:05 PM
I think the discussion...
Originally Posted by Brantel
Chad,
...was about the extra grounding to the airframe at the switch vs. shorting the P-lead terminal to the shield.
The Slick mags. have a specific terminal labeled GND, it should be used....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
