Old 04-30-2009, 03:51 PM
flickroll's Avatar
flickroll flickroll is offline
Default Dumb Fiberglass Question
I have fitted the empennage fairing on my -8 and it looks pretty good. I do need to cover the HS and VS with packing tape and mix up a slurry of epoxy/micro so as to fill any slight misfit between the glass and aluminum parts. My question is how do you hold the fairing in place while the epoxy sets up? If I use screws won't they get epoxied to the airplane? If I try to tape on the fairing it won't fit right. Maybe attach with clecos? Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 04-30-2009, 04:26 PM
tcone1's Avatar
tcone1 tcone1 is offline
You can use vaseline as a release agent on the screws or clecos. I would try to avoid putting any spooge in the screw holes to begin with, but a little vaseline will allow them to be removed without damage.
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
1600 hours on the hobbs and loving it
DanH's Avatar
DanH DanH is offline
Jim,
You do want to screw it down exactly as it will be when finished. All you need is a tiny bead of liquid shim along the underside of the edge, so the screws should not get much exposure to epoxy. However, if you're worried about sticking a screw, coat it with a release agent...which can be a film of grease, a squirt of hairspray, Turtle Wax....
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-30-2009, 04:37 PM
flickroll's Avatar
Thanks guys. When I built a Christen Eagle and assembled the canopy, you epoxied the canopy/skirt/frame together and held the whole thing together with clecos while the epoxy set up. After the epoxy set, you just twisted the clecos and most all of them came out easily, just a few required a little more muscle.
In the case of the -8 I'll keep the slurry to a minimum, and to be safe coat the screws with grease. Thanks again.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 04-30-2009, 04:55 PM
MNAv8or MNAv8or is offline
LOL spooge LOL
Old 04-30-2009, 05:00 PM
Brian Vickers Brian Vickers is offline
Default Liquid shim
Dan,
I have seen you mention liquid shim before. What is your preferred product and where do you get it? When I do a general search on the Internet, there are lots of products called ?liquid shim.? My composite parts could use some minor gap filling.
Brian Vickers
Bainbridge Island, WA
RV4
Old 04-30-2009, 05:33 PM
DanH's Avatar
Just my loose term for epoxy mixed with a filler to close a cosmetic gap in composite parts. Which filler depends on what sort of service the part will see. Epoxy/micro is soft, so not such a good choice for exposed edges subject to abuse. Epoxy/cabosil is just thickened epoxy and somewhat tougher. It also flows nicely under pressure but prior to gelling it doesn't flow out of the gap because of gravity. Epoxy/flox is the toughest, but doesn't flow or finish very well. For an emp fairing I'd use epoxy/cabosil mixed a little thicker than toothpaste.
There really are structural "liquid shim" products for sheet metal gaps. I recall somebody with first hand experience in production work talkimg about them in this forum.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-30-2009, 05:56 PM
Default Whew!! Glad I don't have another product to buy!!
Wonderful, I already have cabosil and epoxy on the shelf. Thanks for taking time to share information.
Brian Vickers
RV4
Old 04-30-2009, 07:00 PM
RV505 RV505 is offline
This is what we used at United. Great Stuff
http://www.henkelna.com/cps/rde/xchg...UID=0000000IS8
