Old 04-30-2009, 02:40 PM
N200PF's Avatar
N200PF N200PF is offline
Default Oil Coolers - SW vs. Aero Classic
It's time to buy my oil cooler and like most RVer's I really don't want to be chasing oil temp issues in phase one. After searching the archives here, it seems that airflow has as much to do with oil temps as the cooler but getting the right cooler is important too.
In ordering all my firewall forward parts from Van's I see that they sell a Stewart Warner STYLE cooler which is what started me looking around because I wanted a real Stewart Warner based on everything I read. ...then I found the Aero Classic coolers.
The question I have is on anyone's impressions of the Aero Classic coolers. They are lighter and certainly less expensive but I'm more interested in keeping my oil temp in check than saving $100.
Is anyone flying one of these and if so...what are your impressions.
Thanks! - Peter
PS - I'll be cooling the oil in an Aero Sport IO-375-M1S with the extended James Cowl.
Peter Fruehling
St. Paul, Minnesota - Based at ANE
RV-4 - Sold
RV-7 - Sold
RV-10 - Partners in N829EC
2019 Dues Paid - Have you paid yours?
Old 04-30-2009, 03:13 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Setrab
A lot of people are using the Setrab 110. Lower cost, better cooling and lighter so it's less stress on the baffling.
I am not using one so can't say if what everyone says is true or not, however some of the Rocket guys who I trust are very big on them. There are a lot of threads that talk about them. Do a search on "Setrab."
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 04-30-2009, 03:32 PM
Geoff
Posts: n/a
Thanks! - Peter
I had to swap my original Niagra for a SW of the same size -- it resulted in a 10-15 degree drop.
My two cents? Buy the biggest and best oil cooler that will fit. You can always cover it up if you have too much cooling capacity. That's a lot easier than remaking the baffle later on if you find out your oil runs too hot.
