Old 04-30-2009, 06:56 AM
MCA's Avatar
MCA MCA is offline
Default Borescope Pics at 500hrs (Lycoming IO-390)
For the RV-7's third annual inspection, I figured it would be a good time to see how the inside of the engine is holding up after almost 500 hrs. The differential pressure check passed with flying colors, and a friend had a good borescope he was willing to bring by the hangar. So we took some pictures and sent them off Bart at AeroSPort Power and Allen and BPA, who both said everything looks fine. I'm glad, because I have no clue what to look for other than obvious defects.
Anyway, the pictures were interesting and thought others might want to see. To me, they looked very different than what you might expect just seeing a piston or valve out in the open. The pictures below are from different cylinders.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 04-30-2009, 07:50 AM
llavalle's Avatar
llavalle llavalle is offline
Wow, what kind of borescope was it?
Philippe Marseille
RV-9A Kit Emp done, wings @50% - SOLD
RV-12iS@Empennage
Construction Web Cam
Old 04-30-2009, 08:30 AM
cguarino cguarino is offline
Default My Guess
General Electric
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
Old 04-30-2009, 09:19 AM
BikePilot's Avatar
BikePilot BikePilot is offline
Wow, very high quality pictures!
Is that lead burnt onto the piston?
They cylinders sure don't show any wear, you can still see the cross hatcing
Student pilot and RV wanna-be
Old 04-30-2009, 11:18 AM
frankh's Avatar
frankh frankh is offline
Default Depends
On where your looking..Wear on a cylinder usually starts on the thrust side of the bore..I.e because of the position of the crank on the power the piston wants to rock towards the leading side as it gets driven down the bore.
If we were looking at the other side then yes I would expect to see the cross hatch....
Was the cross hatching visible all the way round the cylinder?..if so thats pretty good for supposedly 25% thru the life of the engine.
Frank
Old 04-30-2009, 06:13 PM
N54SG N54SG is offline
Man, thats just cool! I need one of those...
Lancair 360
Best Race Speed: 279.686 mph
Building Lancair Super Legacy
LaminarConsulting.com
N54SG.com
Old 04-30-2009, 06:51 PM
frankh's Avatar
Default We all NEED
one of those..
Old 04-30-2009, 07:03 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Neat shufti-scope - as they'd probably say in the RAF
Old 04-30-2009, 07:48 PM
osxuser's Avatar
osxuser osxuser is offline
Looks pretty good. Yeah the deposits are lead... and the cylinder cross-hatching is pretty typical.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 04-30-2009, 09:10 PM
BikePilot's Avatar
Thanks! Other than helping pull the cylinders off our tow plane when I was flying gliders, I'm new to aircraft engines. I have pulled bike engines down and saw one that still had the cross hatching even after 60k miles (and an NHRA championship). I don't know what the bore surface is on a lycoming but the cylinder plating used in bikes and cars these days seems pretty extraordinary!
