Originally Posted by nucleus
But as long as my temps are okay, should I run 50 ROP in that 6500-7500 to improve my break in?
Hans
If you are going to run at 6,500 to 7,500 ft, and at or near full throttle you will most likely be over the 75% max allowable cruise setting. My non-expert advice is, take off excepted, limit your self to 75% max and follow Lycoming's recommendations: "Maximum Power Cruise" (approx 75% power). Never lean beyond 150 degrees F on the rich side of peak........ Monitor cylinder head temps."
Fin
9A
