Old 04-28-2009, 11:39 PM
jdmunzell jdmunzell is offline
Default Bandsaw techniques?
Just wondering if there any secret techniques used in cutting aircraft aluminum with a bandsaw. I use a metal fine toothed blade on mine, which helps move things along, but I still get some drift off of my line that is very hard to correct. What do you guys do to prevent/minimize drifting off of the cut line?
Jeff
-8 wings, finishing up
-8 QB Fuse just arrived!!!
Old 04-28-2009, 11:48 PM
G-force's Avatar
G-force G-force is offline
Make sure the upper and lower guides are adjusted properly, this is key. Use the longest (front to back) blade your machine will take, and lower the upper guide as low as you can. Also, keep the blade at its maximum tention. Last, a new, sharp blade will cut straighter. Other than that, its just hand & eye coordination with a bit of luck
Mike Sumner
Castaic, Ca
Old 04-29-2009, 12:07 AM
PCHunt PCHunt is offline
And don't cut right up to the line. Use a file or a 3M wheel, as appropriate, to finish the job.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 04-29-2009, 04:53 AM
pierre smith's Avatar
Default It's called lead angle, Jeff...
....and it means that you cannot use a fence like you do on a tablesaw. The blades are punched and there's a slight burr on one side.
Take a piece of thin, rectangular wood like paneling and draw a straight line from one edge to the other, parallel to the edge. Then start cutting along the line until you get half way through and shut off the bandsaw while holding the piece of wood still until the blade stops. Now draw a pencil line on the table along the edge of your piece of wood. You'll now be able to see the "lead angle" of your blade...usually a few degrees off from the fore/aft grooves on the table. That is the angle that you need to make a straight cut....years of woodworking taught this.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-29-2009, 05:29 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default Band saw technique
Pierre is right, bandsaw drift is a fact of life. Takes a little practice. I worked as a cabinetmaker for years, as well as an auto mechanic, and machinist. One tip I will give you is to always "stone" the BACK SIDE of a new bandsaw blade to remove the stamping burr. Run up and tension the blade, then gently lay a stone to the rear of the running blade in an effort to round off the back of the blade equally on both sides. It just takes a little, and the results will surprise you. Also, better blades are out there, such as the Timberwolf brand, which are ground as opposed to stamped. They are more expensive for sure, but last longer. Also, a blade lubricant will really help, Boe lube stick is great, and you probably have some. You may want to try a coarser blade on your saw once you have some practice. They cut more aggressively, but last a bit longer. They don't load up with chips as fast, and run much cooler. Noisy as heck though...
Hope this helps,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 04-29-2009, 06:37 AM
Thanks guys for the tips. I wondered also if scoring the surface on the path you want the blade to follow would help the blade stay in the "track". What do you think?
Jeff
Old 04-29-2009, 06:58 AM
vlittle's Avatar
vlittle vlittle is offline
I found that "metal cutting blades" are no good for aluminum. What you need is a wood cutting blade. Cuts fast and does not load up.
The quality of the blade counts, too.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 04-29-2009, 07:13 AM
I was using a wood cutting blade for most everything, but switched to a metal cutting blade for cutting some fairly thick stock, as I am making the flap attach brackets.
Jeff
Old 04-29-2009, 07:15 AM
Mel's Avatar
Mel Mel is offline
Vern is right. Wood cutting blades seem to work better on aluminum. The teeth are too close together on metal cutting blades and tend to load up with aluminum.
Lubricating the blade also helps the aluminum not to stick. I have an old stick of "door ease" that I coat each side of the blade with. "Pam" cooking spray works as well.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-29-2009, 07:26 AM
Sid Lambert Sid Lambert is offline
Also, take your time. If you try to cut to fast it will wonder around on you.
I use Boelube on my blades and have not replaced but one. (my fault for trying to cut a hinge pen)
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
