04-28-2009, 10:10 AM
Boss Mount Alternator Bolt Torque Help!!!
Hi Folks,
I bought a 60A planepower alternator for my RV-8. When I started the alternator installation I couldn't find torque value for bolts, plane power manual said to use torque value specify on engine manual. Unfortunately the manual and DVD that came with my new Lycoming YIO-360 doesn't have to much important information, I think I supoust to by a real mechanich maintanaince manual
OK so please could help me with torque value so I will be able to finish my alternator intallation.
Thank you
04-28-2009, 10:16 AM
Van's table?
Why don't you use the table from Van's in the manual?
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
04-28-2009, 10:23 AM
Sitting here at the coffee shop I can't help you with the torque value. If no one else posts it I'll post it later after I've been to the shop. Sacremento Sky Ranch and several other sources sell Lycomming overhaul manuals pretty reasonably. Overhaul manuals come complete with a table of limits that pretty much outlines every measurment in your engine. It's a must have in your hanger tool kit.
04-28-2009, 07:30 PM
You are right, I must buy an overhaul manual for my engine, problem is I am in Chile and is going to take some time to get it. Please send me the info that you have for those bolt so I continue working on my engine.
Cheers
04-28-2009, 08:02 PM
It's not specifically listed...
..in the Overhaul Manual, probably because the alternator is usually considered an airframe part, and not an engine part on certified planes.
The general Lycoming torque values should work for these bolts -
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
04-28-2009, 08:25 PM
The bracket mounting bolts are 5/16-18.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
04-28-2009, 08:45 PM
Great folks thanks
10-14-2018, 05:20 PM
Stud Torque?
So is 25 in-lb min. the torque used for these bolts with the alternator bracket due to them going into the threaded engine case?
John Johnson
Murphy, NC
RV7
10-14-2018, 07:35 PM
OK, I see; 17 ft-lbs
John Johnson
Murphy, NC
RV7
10-14-2018, 09:09 PM
Regards, Tonny.
This would be a better one since it covers the coarse thread Lycoming engine bolts rather than the fine thread airframe bolts of Vans numbers.
Gil Alexander
