Old 04-27-2009, 07:46 PM
kritsher kritsher is offline
Default how much is enough primer?
I don't want to start a new primer war; this post is about quantity, not quality. For the record, I'm using rattle can self etching primer (used Marhyde on the tail, trying Napa 7220 now). I just finished priming the main ribs for my left wing, and I don't know if I'm using too much, too little, or if I'm doing it just right.
Today, it took 2 cans of 7220 to paint 14 main ribs. That seems like a lot to me, and so I'm worried I'm using too much paint. I try to put on an even light coat. Right after I spray the paint, when it's wet, it looks good, like a nice even translucent coat. The part looks completely covered. But, when when the paint dries, it starts to look splotchy (with some parts darker than others) and also "speckly" like there are little pinholes with what looks like bare metal peeking through. That makes me think I need to put on another coat. But I've already used 2 cans!
I want to keep the paint as light and thin as possible, but I want adequate protection.
How do I know I've put on enough, but not too much?
Old 04-27-2009, 08:23 PM
Mel's Avatar
Mel Mel is offline
Typically if you ask, you are using too much. Very seldom have I seen too little.
Too much just adds weight and cost.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-27-2009, 08:50 PM
aarvig's Avatar
aarvig aarvig is offline
Default Show us
Would you mind posting some pictures of what you are talking about. I am no expert on the subject but I will be facing some of the same concerns you currently are and I wouldn't mind seeing how much you are putting on. Maybe the pics will give someone a better idea of whether or not you are going to heavy.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 04-27-2009, 09:32 PM
danielhv's Avatar
danielhv danielhv is offline
I was told to "dust" the parts with the primer. You're not painting. Just priming. Light dust, and move on. It took me 1 can to do all the ribs for both wings on my -7A.
Old 04-28-2009, 12:05 AM
ignacio ignacio is offline
i had the same problem and just sprayed over again. i dont even know how many cans ive gone through but at 10 bucks a piece and just started the fuse, i sure wish it was less cans. some will say its just fine if just sprayed once but if not prepped right it will just scratch or peel off. i like the look of the 7220 gray so i just spray it on till fully covered.
Old 04-28-2009, 02:20 AM
Rivethead Rivethead is offline
You should almost be able to see through it. You're probably using to much.
Old 04-28-2009, 08:49 AM
DickDe DickDe is offline
Default Primer coats
I was taught during a Luscombe rebuild in the 1960's, that primer (Zinc Chromate was "THE" primer then) to spray the coats even but only enough that if the surface was a newspaper, the print would still be readable after you are finished. Based upon this lesson I usually thin primer 50% to keep the coat light and the type, brand, etc. of the primer doesn't seem to matter much. I am on aircraft project number 8 now and have used various products but still follow this original rule especially on the interior structure.
Dick DeCramer
RV6 N500DD 300 hrs. flying
RV8 Fuselage
Northfield, MN
Old 04-28-2009, 01:38 PM
SvingenB SvingenB is offline
It depends on what kind of primer you are using and the material.
Alclad do not generaly need any primer because the cladding is anodic to the core and protect the core electrolytically. The only real reason to prime alclad is to make it waterproof and/or protect it electrochemically along rivet lines etc where water can collect and stay for longer periods of time.
Non clad material needs real protection, waterproof and preferably with chromate.
So how thick a layer? It depends. Chromated epoxy will give you a very thin waterproof and tough layer with added electrochemical protection (There are Strontium Chromate epoxy primers made especially for this purpose, and they are sold by most manufacturers of industrial aviation paint). Zinc Chromate spray cans does not need to to give you a waterproof layer, but protects the aluminum electrochemically when water enters, and only a very thin layer is needed. Non chromate stuff will only protect by blocking out water, so the layer has to be as thick as needed to make it waterproof (low pigment wash primers are probably best in this respect with a very thin waterproof layer). Many self etching non chromate primers give a (sometimes thick) porous layer and that does not sound very waterprooof to me.
RV-4 #4520, Slow built
B Svingen
RV-4 Project Log
Onex Project Log
EAA Chapter 573 Norway
Old 04-28-2009, 06:25 PM
avee8tor13 avee8tor13 is offline
Default just enough to cover the mating surfaces
When I first started I primed everything, lightly then I primed just enough to cover the mating surfaces where two pieces of aluminum came together (rib and wing skin). Check out this link.
http://www.avee8tor.smugmug.com/gall...22236989_6dRtk
You will notice I left the open areas alone, they are alclad coated.
Ignore the old ugly fat guy.
Old 04-28-2009, 09:54 PM
danielhv's Avatar
I did the same on the wing skins... no need to prime everything. Just mating surfaces (in regards to skins...)
