Old 04-27-2009, 07:45 PM
markscogg markscogg is offline
Default Carb Float SB - applies to Facet MA-4-SPA?
Does the float SB need to be done on my carb?
Here is what's on the carb:
MA-4-SPA
10-5135
CK 9 18985
FAA PMA FACET
Engine is O320-D2J. Was on a Skyhawk for 2000 hours in the 80's and 90's before it was overhauled. No mention of carb work in logs.
Mark Scoggins
Charlotte, NC
RV-6 bought,flown and sold.
Rv-4 bought, flown and sold.
Old 04-28-2009, 06:35 AM
ABRV4 ABRV4 is offline
Default Float SB
Mark,
My guess is that the SB has not been done. I believe that the carb should have an M (indicating the addition of a metal float) stamped on the data plate if this SB has been complied with. It is easy to remove the four screws holding the bowl in place and drop it for a look inside. I will add that since that SB was issued that some of the metal floats sold for the repair have had another SB sent out warning about a possible leak developing in them. Good luck.
Alan
RV-4 N7028K
Old 04-29-2009, 06:38 PM
Default Metal floats
Since the carb was made in the 80's, wouldn't if have the old metal floats?
Are the new SB floats metal or plastic?
Mark Scoggins
Charlotte, NC
Old 04-29-2009, 07:16 PM
wv4i wv4i is offline
Default new floats
They're made of solid epoxy, at least for the MA4-5.
If you can't determine SB application, then either check Tempest/Volare website or call Vince Bechtel at 843-991-1199, although he did say email is better: VinceBechtel@tempestplus.com
Link McGarity
Wellington, FL (FD38)
RV6/N42GF bought flying, sold
RV6/N72AT bought flying, sold
B737-800/NxxxAN
Sonex TD w/Aerovee/N732SX bought flying
Old 04-29-2009, 07:25 PM
Dmadd Dmadd is offline
I have same carb and engine from the same era. Didn't apply to mine.
DM
Old 04-30-2009, 01:16 PM
rv7charlie rv7charlie is offline
This is *not* an effort to tell anyone what to do or not do about SB's & AD's, but isn't it interesting that every time design ownership of that carb changes hands there's an AD or SB issued.....
Charlie
