Old 04-27-2009, 05:04 PM
prkaye prkaye is offline
Default flush primer lines before 1st start?
Can fuel be flushed through the primer lines with them not connected to the intake ports before first engine run, to flush out any residual debris in the lines and to check for leaks? Would this damage the fuel pump or primer solenoid?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-27-2009, 05:45 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
I don't think it will hurt the pump. But i did it a different way. I flushed my primer lines out with Carb cleaner just before installing the lines from the gasolator to the primer solenoid and the lines to the cylinders. Mine worked fine for the first few hours, and then something plugged the primer line to the #4 cylinder (Have only two primer lines, #2 and #4 cyl). Had to remove it and flush it again. No issues for 56 hours so far.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 04-28-2009, 04:25 AM
tinman tinman is offline
I have a question regarding how much priming it takes using the solenoid valve primer and a facet pump. I am having a difficult time starting my carbureted o360 and wondered if perhaps I am not priming enough. I turn on the facet pump and watch the pressure build up. Then I hit the primer solenoid for about 4 seconds and then spin the engine. It takes a couple of these to get things going. Am I not priming enough? Does the carb have a booster pump that will squirt fuel if I pump it during the start attempt? I figure that it is better to not have too much fuel and risk fire...
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
Old 04-28-2009, 05:19 AM
pierre smith's Avatar
Default Hi Don.......
.....We have the same primer/carb setup but what I've seen guys do is open the throttle too far. It barely needs to be cracked (Yes, it does have an accelerator pump....we give three strokes) so that the velocity of the up-flowing air is fast enough to carry fuel uphill to the cylinders. Try cracking the throttle no more than 1/8". This leaves a very small clearance between the butterfly and the venturi of the carb, making for fast airflow.
You can leave it in this position then walk around to the front with the mags off and pull the prop toward a compression stroke without going over top center and let it bounce backward. Do this two or three times and you should hear a "slurp...slurp" each time, near compression. This tells you that the throttle is open just right. If there's no "slurp...slurp", it's open too far.My late boss taught me this trick before I propped the Super Cub.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-28-2009, 07:18 AM
Default carb cleaner?
What is carb cleaner? How did you push it through the primer lines?
Phil
RV9A (SB)
Ottawa, Canada
Old 04-28-2009, 08:45 AM
Chino Tom's Avatar
Don, 4 seconds is not enough. If the engine is cold, 15 seconds does the trick for me. If it is warm, 5 - 10 seconds works. I don't like to use the Carb's accelerator pump because of fuel pooling in the airbox. But i know some who have no primer systems and have no problems.
Phil, I just went to Kragen Auto parts and bought CRC carb cleaner (spray can). Attached the
red tube and blew carb cleaner through the lines (off the airplane) through the nozzle side back. Then installed all the lines. After the first few flights, the airplane became hard to start even with 15+ seconds of priming. I removed both primer lines at the cylinders and pressure tested the system using the facet pump which is how i found out the #4 was plugged. I removed the #4 line and used the carb cleaner as I had during install and it cleared it. Never saw what was in the line.
Tom Prokop
Chino, CA
Old 04-28-2009, 08:56 AM
Danny7 Danny7 is offline
a cheap solvent usually found in aerosol cans. there are generic brands in every auto parts store
nothing special here...
Old 04-28-2009, 09:08 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
My favorite is B-12, http://www.berrymanproducts.com/Default.aspx?tabid=138
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-28-2009, 09:14 AM
Wow! 15 seconds...that seems like a long time which explains why mine must not be getting any fuel from only four seconds. Those tiny lines must not pass much fuel.
Don Alexander
Summerville, SC
Old 04-28-2009, 09:24 AM
647jc's Avatar
647jc 647jc is offline
I agree, 15 seconds seems very long. I once primed mine for about 6 seconds and the engine acted as if it were flooded, coughed and sputtered. I now only prime for 4 seconds cold and not at all when warm. I have an O-320 with 3 primer lines and it seems to take quite a few blades before it fires up when cold. I sometimes pump the throttle once while cranking after about 4 seconds if it hasen't already fired, that usually does the trick.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
