Old 04-26-2009, 11:58 AM
tcone1's Avatar
tcone1 tcone1 is offline
Default Cheap source for Primer Solenoid
http://cm.ebay.com/cm/ck/1065-29392-...m=300308805474
I found this while looking for a solenoid that would handle more pressure than the Parker b2dx62, my homebrew smoke system was jamming the parker valve closed.
I bought one and will report back after testing.
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
1600 hours on the hobbs and loving it
Old 04-26-2009, 08:19 PM
Christopher Murphy Christopher Murphy is offline
Default smoke syst
What pump are you using on your home brew smoke system. I am building one and bought the pump the smoking airplane guy uses and it puts out 60 psi. The selonoid is rated at 25 psi. I called the pump manufacturer and they said not to pump oil with that pump so I am planning to change to a facet fuel pump 6psi. What is the pressure of your pump?
Chris Murphy rv-4
Old 04-26-2009, 08:42 PM
Norman CYYJ Norman CYYJ is offline
I have used the facet pump made for diesel engines with good success.
