Old 04-25-2009, 07:47 PM
larrym larrym is offline
Default Fuel sender problem
This the 2nd time? I have a fuel gauge not working. It is on full all the time, it worked for 8 hrs. Then quit. My 1st time question here covered all of the normal things.Ground, connections,etc. Digging a little deeper. What???
Old 04-26-2009, 05:20 PM
Default fuel sender
Yes, I have tapped gently. No I have not swapped gauges. I have never heard of a failure. I will swap them and see.Thanks
Old 04-26-2009, 08:48 PM
I had a bad gauge and proved it by swapping...Van's sent me a new one free of charge.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 04-27-2009, 12:46 PM
Sticky1's Avatar
Sticky1 Sticky1 is offline
you could also use you DVM (digital volt meter) to check out the sender depending on resistive or cap sender....
