Old 04-24-2009, 12:39 PM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Cool Help for planning steps - panel&electric stuff
I'm well prepared to start putting spaghetti wire into my plane (rv8)
But I need to have some advices from you in order to do the right sequence (or more convenient).
The main question is : when to install the upper fwd skin in order to rivet the panel to it, I think it's not a nice idea reaching the rivet with the bucking bar with the stuff already mounted. But I understand that having not the upper skin give me easier to reach the places for install electrical stuff & more.
- I've the panel cutted & painted, ready for instruments
- My baggage fwd bulkhead has a big window option (to reach the back of the panel if mounted)
- I've my side cockpit panel will all CB & SW in position
- I've not yet riveted the fwd upper skin
Let me know with thanks in advance
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
Old 04-24-2009, 12:51 PM
danielhv's Avatar
danielhv danielhv is offline
Well you're in the right part of the world for spagetti so you cant go wrong there!! Be sure to post some pics!
Old 04-24-2009, 01:03 PM
Default :o)))
But it's not so easy to do a good spaghetti meal
Luke
http://www.rv8.it
CrewRV8 team leader
=VAF= 2020
Old 04-24-2009, 01:14 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I think first you need to choose marinara, or alfredo sauce.
I would wait as long as possible to rivet the skin on, it will make access a lot easier with it off.
The panel is held on with screws, not riveted.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-24-2009, 01:43 PM
sorry, I mean that the instrument panel attachment flange that it's already solidly with the two side sub panels must to be riveted to the upper skin
BTW standard it's the best : Spaghetti, tomato sauce, basil and ground parmesan cheese
Luke
http://www.rv8.it
CrewRV8 team leader
=VAF= 2020
Old 04-24-2009, 03:03 PM
kbehrent's Avatar
kbehrent kbehrent is offline
On my -9A slider, I avoided doing any riveting on front panel structure until all the avionic trays were fitted and EFIS depths were confirmed in order to determine if/how much the rear panel bulkheads would have to be cut to accommodate trays and wire access. Once that is done, the structure can be riveted. The top skin will not get riveted until all my wiring is completed and tested. I have NO desire to go diving under my panel!
When doing your electrical layout, just imagine how you would go about fixing/trouble shooting your installation. Now, take that nightmare and redesign your layout and access points to avoid the nightmare!!
I'm using a modular panel that is easy to remove to gain access to the back of my panel. My fuse blocks are hinged for each drop down. All other items that will be installed behind the panel will have nut plates for easy removal.
Good luck.
Kevin Behrent
TeenFlight Puyallup, President
www.teenflight.org
http://facebook.com/teenflightpuyallup
EAA Chapter #326
Puget Sound, WA
RV-9A
Aerosport (Superior XP) IO-320 C/S, Precision Eagle EMS
Old 04-24-2009, 05:55 PM
Craig23's Avatar
Craig23 Craig23 is offline
Default I'm waiting on the skin
I'm at about the same point in my construction. I have a maze of wiring installed for my panel. Everyone has told me to wait until the wiring is in before installing the top skin. My plan is to get everything installed on the subpanels, finish up all the wiring/plumbing forward of the panel, and then rivet on the top skin. Once that is done I'll get to work on my baggage door and attach the main panel. I also have a large access door in the aft baggage bulkhead so I can access the panel, but I think it will be much easier to make all my wiring connections with the skin off.
Craig Schwartz
RV-8 (Flying!), IO-360B1PC2 (180 hp, 1 P-Mag, 1 Slick Mag), Whirlwind 200RV, AF-3500, G496, Digiflight II, Classic Aero Sportsman Ultraleather Seats
N868RV
Santa Rosa, CA
Old 04-24-2009, 09:21 PM
ericwolf ericwolf is offline
As others have said, wait as long as you can to rivet the forward deck skin. I waited until I had to mount the windscreen.
When I riveted the forward deck skin, I had the panel installed with all the wiring and pitot/static plumbing and didn't want to remove the panel. I removed the AFS3500 and I had a big enough hole to get my arms through for bucking while I sat in the pilot's seat.
I also have an access panel from the forward baggage compartment (which is absolutely invaluable), but it would be very difficult to do all the wiring with only the access panel.
Eric Wolf
RV-8A Flying since May 2009, 300+ hours
Mattituck IOF-360, WW 200RV Prop
N184EW
Past President, EAA838 Racine, WI
Old 04-25-2009, 04:20 AM
pierre smith's Avatar
Default Kevin's idea...
Originally Posted by kbehrent View Post
..... Now, take that nightmare and redesign your layout and access points to avoid the nightmare!!
Good luck.
......is definitely the way to go. I'm doing a -7A now and it will have a three-piece modular/removable panel with long enough wiring to lay back in the cockpit for future access. I've already been under my -6A for a TruTrak install and an SL-30 upgrade.....no fun at all.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
