Old 04-23-2009, 07:05 PM
7DeltaLima 7DeltaLima is offline
Default male or female conn. for digiflight?
what's the gender of the 25 pin p101 that I need for the digiflight II ap? Waiting on the AFS AP and 4500's but would like to finish up the wiring.
Thanks in advance,
Doug
Doug
RV-7A N277DL flying 4-15-2004
RV10 N277CK flying 5-28-2010
www.oncloud7.com
Old 04-24-2009, 10:48 AM
SteinAir SteinAir is offline
You need a female connector (that is one that uses female sockets)...
Stein
Old 04-24-2009, 11:31 AM
Thanks Stein, guess I could of just called you, huh.
Doug
Doug
www.oncloud7.com
Old 04-24-2009, 02:29 PM
breister breister is offline
To be fair, they ought to have a picture of the back of the unit in the installation manual, or the wiring diagram ought to have a detailed enough view of the connector to discern it's gender...
Old 04-24-2009, 04:54 PM
I don't know for sure, but I'm guessing they never really thought about it because they supply the mating connector for free with each autopilot shipped. I suppose they figured that since the connector was/is supplied with the AP, then it wouldn't matter. That being said, I also be we'll see a change/add to the manual as suggested because for those who either don't have the mating connector or want to do the wiring early without purchasing a pre-made harness it would be good to identify in the drawings.
Stein
