Old 04-23-2009, 03:48 AM
thinkn9a thinkn9a is offline
Default tool to lock in Garmin gtx-327 transponder
where do I find it and what is it?
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
sjhurlbut sjhurlbut is offline
To set the transponder in the tray?
3/32" allen key.
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
Old 04-25-2009, 09:50 AM
Default ok,.. but what about tool for front of unit,...?
don't you adjust depth of cam from front,.. then lock in with allen?
9A -QB
N211LV
Old 04-25-2009, 10:27 AM
a8301 a8301 is offline
allen wrench rotates the cam then it tightens down as you turn it
Old 04-25-2009, 10:33 AM
noelf noelf is offline
Default The allen tool...
...is inserted into the front of the Garmin unit.
The threaded fastener in the Txponder has a socket head that accepts the allen tool. This fastener is threaded into a cam flipper that is internal to the front of the Txponder unit.
You should start the installation by first using the tool and turning the tool / screw in a CCW direction. This will swivel the "cam flipper" and position it in the proper position / orientation for the install. Once the flipper is fully retracted, insert the unit in the tray, and while lightly pushing the unit in...use the allen tool and turn CW until you feel resistance against the turning.
Turning in the CW direction caused the "flipper" to flip, rotate into the slot on the front of the txponder tray, and will "cam" (pull) the unit into the tray as the allen tool is turned.
Old 04-25-2009, 02:56 PM
rv72004 rv72004 is offline
Also just do a dry run with the unit out and you will see how its supposed to work.
EJ
RV7 flying
xp360, CS, All Glass cockpit
Old 04-25-2009, 03:08 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
FWIW --- Some radios/transponders/etc. will have trouble using allen wrenches with a "balled" end. Others have no problem at all; but be aware.
L.Adamson
