The big day has finally come.....The fuse is moved to the airport.
After much worry (needless) and loss of sleep ( I am an old man..think of it as extra life) the aircraft hauling truck arrives.....
On the road to 1L8. Extra points for naming the peak in the picture!!!
One step closer to the day when this machine will be in the air. It is finally in a real-honest to goodness aircraft hangar faciltiy.
Like most activities in building the plane, proper preparation/$$$$$$$$$$$/and help from good folks the job got done with out a problem.
Frank @1L8....RV7A...finally at the airport ...at least the fuse is.
