Old 04-20-2009, 06:35 PM
prkaye prkaye is offline
Default bonded-only spanwise wingtip rib
For the wingtip rib that runs spanwise, the plans have you bond it first and then rivet it with 3/32 rivets. These rivets will have to be set with a rivet gun, because it's too deep for a squeezer to reach. I'm not crazy about smashing that thin fiberglass tip with a rivet gun, so I'm thinking about just relying on the epoxy to hold it in place. I would think with a sufficient amount of epoxy this would be more than strong enough. Thoughts?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-20-2009, 07:13 PM
BlackRV7's Avatar
BlackRV7 BlackRV7 is offline
Phil, if you are going to bond it, get some cotton flox and go ahead and drill some holes in the rib flange for the flox to flow through and have at it. The holes add some strength to the bond. Be sure and scuff the rib flange up nicely. The people in the plastic airplane world do it all the time.
Either that or Van's has soft rivets just for fiberglass.....
Dana Overall
Richmond, KY i39
http://www.DanaOverallCPA.com
Repeat offender, RV-10 emp
Builder/former owner, RV-7, "Black Magic" Flying
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
VAF #993
Old 04-21-2009, 05:58 AM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default pops
set pop rivets just below the surface then cover later with microballoon mix or rage filler. Then you have rivets but you don't see them.
Old 04-21-2009, 06:19 AM
Dave Cole's Avatar
Dave Cole Dave Cole is offline
Default Bonding stronger than rivits
If you bond the rib in place with an epoxy and cotton flox mixture, the result will be significantly stronger than plain epoxy with rivits. I would leave the rivits out provided you can devise a way to hold the rib in place while the epoxy cures.
Dave Cole RV-7 N97DC reserved
dave.cole@cox.net
Started SB April 2004
Hope to fly in 2011
Old 04-21-2009, 06:24 AM
f1rocket's Avatar
f1rocket f1rocket is offline
There are a number of ways to attach it, some are more work than others. My suggestion is to Proseal it in and leave it at that. I don't think drilling holes are necessary, but they certainly won't hurt anything either. They do give you some extra grip but with Proseal, I don't think it's needed. Flox by itself is a weaker bond IMO without glass over the top of it.
Personally, I try not to pop rivet anything if I can help it but that's just a personal preference. When you bury pop rivets underneath Bondo, slurry, etc, they tend to vibrate and eventually crack through your paint. They just are not as tight as a solid rivet and I prefer to avoid their use if I can get away with it.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 04-21-2009, 08:18 AM
Thanks guys. I do have a bag of cotton flock, so I'll use this with epoxy, and drill the holes in the rib as recommended.
I've actually become a huge fan of fiberglass... so versatile!
Phil
RV9A (SB)
Ottawa, Canada
Old 04-21-2009, 11:15 AM
vonjet vonjet is offline
Default Hysol.
I'd maybe look at using Hysol. Not sure about the bond quality with metal but its a heck of a lot better for fiberglass bonds. We bond all our fiberglass skins together with it in the Lancair and its incredible stuff. And you dont want to use excess epoxy for anything. Try and get your bond line thin but not to thin. Drilling holes in the rib is a good idea for the glue to flow out of and help grip.
Another great product for bonding disimilar materings is made by West Systems. Its called Gflex 650. Its strong and a little flexible.
"Toughness and Flexibility G/flex has been toughened. This gives G/flex the ability to make structural bonds that can absorb the stresses of expansion, contraction, shock, and vibration. G/flex is resilient and impact resistant. With a modulus of elasticity of 150,000 psi (WEST SYSTEM 105 Resin/205 Hardener has a modulus of elasticity of 450,000 psi), G/flex is more flexible and can deflect further than WEST SYSTEM 105/205, while being much stiffer than typical adhesive sealants."
Bryan
