Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 04-20-2009, 11:04 AM
turbo's Avatar
turbo turbo is offline
Thumbs down Failed XM WX Antenna/ 496 settings also
i had a xm wx antenna for 496 fail.garmin said the cord is prone to failure if bent a lot. $110 repair fee. i am posting pic of my 496 page with my settings. the right column is the wx info. the bottom left is nearest vortac for flight following info. the next pic is flight extention line. it can be turned on from map page. menu, set up map, scroll right to this page and set preference. great flying
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 04-20-2009, 11:53 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Hi Turbo - sorry about your expensive antenna wire.
Thanks for posting the 496 settings. I use the extension line (I like it shown in time, where I'll be in 1-5 mintues). I've never seen the weather data like that... do you know where it gets the data? Nearest METAR? Doesn't look like winds aloft, is it?
dave
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 04-20-2009, 12:09 PM
rocketbob's Avatar
It should still be under warranty, you bought it last fall (wink, wink).
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 04-22-2009, 06:21 PM
turbo's Avatar
Default nearest wx?
dave
i believe it comes from the closest metar. love my 496.
Ed D'Arcy
