Old 04-20-2009, 09:28 AM
prkaye prkaye is offline
Default drill size for #4 screw?
What size hole should be drilled for #4 screws? (wingtip attach screws).
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-20-2009, 09:48 AM
Radomir's Avatar
Radomir Radomir is offline
I thought those were #6 per plans? Unless you're "downsizing" #27 drill bit for #6 screw..
But generally speaking, you can find online drill and tap chart for all screw sizes. it's a very handy table...
Radomir
RV-7A sold
Old 04-20-2009, 10:07 AM
I've decided to go with the #4 screw-kit from Cleveland for wingtips, as others here have done. #4 screw has at least the strength of a 1/8" rivet, I believe. Anyway, I think I found what I need... #32 drill for close-fit, #30 for loose fit. The countersink cutter says pilot hole #33.
Phil
RV9A (SB)
Ottawa, Canada
