Old 04-20-2009, 12:07 AM
rv72004 rv72004 is offline
Default Rivet gun oil ?
I have been using any spray can oil to lube the gun before and after working. WD40 and others have been used.
Can this cause long term damage? This is what Ive been told.
EJ
RV7 flying
xp360, CS, All Glass cockpit
Old 04-20-2009, 12:27 AM
gasman gasman is offline
MARVEL AIR TOOL OIL............
USAF says three drops per day........
Old 04-20-2009, 07:13 AM
Mel's Avatar
Mel Mel is offline
Default NOW HEAR THIS!
WD-40 IS NOT AN OIL! It is a Water-Dispersant. It will lubricate temporarily but then is leaves a residue that attracts dirt. Please do not use WD-40 as a lubricant!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-20-2009, 02:03 PM
chaskuss chaskuss is offline
I'm with Gasman. Marvel Mystery oil has kept my cheapo right angle die grinder alive for 9 years! I use a few drops on each tool, every day I use the tool.
Charlie Kuss
Old 04-21-2009, 09:10 PM
rv8eh rv8eh is offline
Default air tool only, except....
I inherited a rivet gun that had sat in the toolbox for about 10 years.
Three drops of air tool oil, nothing moved.
I ended up using some wd-40, and letting it sit in various orientations for a day. Then, three drops of air tool oil, and try again.
brrrrrp.
Air tool oil is available pretty much anywhere, including Sears.
Use it.
Too much can negatively affect tool performance as well as getting you and the work surface, and surrounding area oily.
Howard McKay VAF 573
RV-8A, empennage/wings
