Old 04-18-2009, 11:37 PM
cln1owner's Avatar
cln1owner cln1owner is offline
Default Best way to strip powder coat
Mounted my my WD-613-EF flap actuator tonight. When drilling the F680 block (center) it doesn't line up with the area not powder coated...
What's the best way to strip the powder coat off and leave a nice smooth surface? Should I just leave it as is?
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
"If you think you can do a thing, or think you can't do a thing, you're right." -- Henry Ford
Old 04-19-2009, 05:16 AM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Sandpaper works fine.
Old 04-19-2009, 07:15 AM
yakdriver yakdriver is offline
Regular paint stripper works great. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 04-19-2009, 07:33 AM
rv9aviator rv9aviator is offline
I used 180 grit 1 inch wide emory cloth around the tubes to move the paint line over.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 04-19-2009, 08:45 AM
He wants to leave a smooth surface. Tape the area off with good masking tape, brush on a little stripper and wash it off. Take you about 5 minutes to do that area. Don
Next project?
Old 04-19-2009, 10:39 AM
cln1owner's Avatar
Thanks guys.... I'll give the stripper a try.
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
Old 04-19-2009, 11:43 AM
scsmith scsmith is offline
Default Good Luck!
Maybe with an edge to work under, for a small spot, stripper might work OK.
I needed to strip a whole part, and I found paint stripper just about useless.
I ended up spending a loooong time sanding it all off.
If a part can take the heat, it burns off nicely with a torch.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 04-19-2009, 08:33 PM
G-force's Avatar
G-force G-force is offline
For stripping whole parts, try Jasco aircraft/epoxy stripper. Its in a gold colored gallon can at Home Depot. You will need to really cover the part, dunk it if possable, and wait a few hours. It will bubble up, eventualy.
Mike Sumner
Castaic, Ca
Old 04-19-2009, 10:45 PM
I use aircraft stripper from the auto paint store. I think NAPA also carries it. It would take about 5 minutes to do that little job. I have stripped a lot of powder coat. The Cub I'm building needed all of the rudder pedal and control stick bushing areas stripped. Works great. Don
Next project?
Old 04-20-2009, 02:00 PM
chaskuss chaskuss is offline
Default Improving use of stripper
Another trick to improve the use of paint stripper is to install the part inside a plastic bag, AFTER you cover it with stripper. This will keep the stripper from drying out. It also keeps the fumes in. Place the bag outside in the sun, if it's warm out. This will also speed things up.
Charlie Kuss
