Old 04-17-2009, 08:33 PM
Nehi Nehi is offline
Default closing rear fuselage
How many of you guys are closing off the rear of your fuselage to keep the air from drifting foward ? I've been thinking I would close it off, but thought maybe others had some thoughts, pros & cons !
9-A slooow build- DONE & LOVIN IT !!
Nevin Miller - north Idaho
Old 04-17-2009, 08:45 PM
Mel's Avatar
Mel Mel is offline
If you close off the aft end of the cockpit, where is the intake vent air going to go? You need a certain amount of circulation.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-17-2009, 10:38 PM
Default closing fuselage
Mel, I understand if air is coming in the vents it obviously needs an outlet, but I also dont want cold air seeping from the rear when my vents are closed
Mike no need to answer you are really having a bad night !!
