Originally Posted by Bob Axsom
I have heard the antennas referred to as dipole antennas which I would assume is a half wave center feed antenna based on the appearance
That's right.
They could be two end feed half wave length antennas set at an angle for a specific function or there configuration may be something I never heard of back in radio school.
No, the localizer receiving antenna is just a dipole, not two specialized antennas like an ADF with loop/sense antennas or something like that.
The course deviation information is coded in the radiated signal from the localizer transmitter and its antennas. The receiving antenna just has to sample that radiated signal at a particular point in space (attached to your aircraft
) and feed your localizer receiver. Then your localizer receiver has to decode it, and drive the CDI.
I guess it's possible that your antenna is delivering a weak signal, and your receiver isn't handling that very well. Or maybe your receiver needs aligning. (A VOR check on your receiver won't tell you the whole story since a lot of the LOC decoding circuitry is separate.)
Edit: Reread your post and now I see you clearly said the problem is happening with both LOC and VOR. Well, the receiving antenna is the same in both cases, and it's nothing special. But if it's affecting both, it's probably a problem in something shared by both. Curious that enroute VOR checks are OK, but not OK on the VOR approach to Taylor. I assume you had the OBS set correctly for that approach
--Paul
