It will bolt on at least. I'd imagine the pitch stops would not be correct for that HP. If you are just looking for cheap props, you can find Harzell 7666 with the old hub for under $2000 pretty easily, and they aren't exactly shedding blades left and right...
RV4 wing in Jig @ KPOC
RV7 emp built
