Old 04-14-2009, 08:46 AM
prkaye prkaye is offline
Default drain in FAB?
It occurrs to me as I work on the FAB that there is no palce for water to escape. If water gets in there, how can it get out, without getting sucked up into the engine?
I'm wondering why the plans don't call for us to drill a small water-drain hole in the bottom of the FAB (at least I haven't seen an instruction to do this). I suppose one drawback is that it would reduce the air pressure in the FAB...
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-14-2009, 08:52 AM
scard's Avatar
scard scard is offline
Yeah, drain required. one inside the filter space, one outside the filter in my opinion. This is even more useful to let raw fuel out if someone pumps the throttle too much without the engine running.
Scott Card
CMW E-Lift
Old 04-14-2009, 08:57 AM
Is this in the plans? I'll have to check-again. If not, what size drain-holes would you recommend?
Phil
RV9A (SB)
Ottawa, Canada
Old 04-14-2009, 09:08 AM
647jc's Avatar
647jc 647jc is offline
The instructions (page 2 para. 6) say to drill two 1/8" holes at the lowest point of the bottom of the box, one inside and one outside the filter.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 04-14-2009, 02:44 PM
Ron B. Ron B. is offline
Yes, isn't it great that they mention the drains at the beginning of fabrication and later when it's time to position the holes they only discribe the inside hole with the optional drain tube. Got me in trouble as my partner said two were required and I said he was mistaken. Luckily he knew they mentioned at the beginning of the instructions. At least this is what was supplied with the RV-10.
Ron
Old 04-14-2009, 03:29 PM
RV3 Pilot RV3 Pilot is offline
Here's a little hint for finding the low spot. On my 3 (taildragger) I waited till I had mouned the fab with the a/c sitting on its gear, put an ounce or so of red dye in and let it settle and leave a stain mark or sight from underneath with a flashlight. Drill away
Tom
RV3 x 2.
Old 04-15-2009, 09:47 AM
osxuser's Avatar
osxuser osxuser is offline
Put the whole thing together, find where the filter sits, and put one on each side of the filter... done. There are a LOT of RV's out there flying without this, and only two out of three I know of lit on fire .
RV4 wing in Jig @ KPOC
RV7 emp built
Old 04-15-2009, 03:31 PM
N941WR's Avatar
N941WR N941WR is offline
Close but not exact.
Put one small hole (#30) in the aluminum plate that covers the bottom of the K&N air filter. Then put another #30 hole in the low point on the FAB.
This will allow any fuel to drain out of the carb, past the filter plate, into the FAB, and then drain out of the FAB.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-15-2009, 03:33 PM
frankh's Avatar
frankh frankh is offline
Default All of a sudden
I feel warm and fuzzy all over..NOT!
Old 04-15-2009, 08:45 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Fire down below?
I have been debating about installing the filter bypass on my FAB. I am just completing it and need to decide.
I called a local RV-6A driver and asked if he had installed his. He originally did, but gas dripped from the throttle body down onto the plate and through the door gap onto the bottom of the cowl. During a engine start he had a FAB box fire. Fortunately as the engine started it extinguished the fire. He didn't know this until he inspected the FAB and found it damaged. He promptly removed the filter bypass valve and glassed in the bottom.
His recommendation was to glass in a piece of 1/4 aluminum tubing to the outside bottom of the FAB, drill the drain holes into the tube and run a hose to the lower firewall/cowl exit. Similar to the fuel pump overflow/pressure relieve vent tube run per the plans.
Food for thought...............
Paul
