Looks from this table (from
http://www.faa.gov/airports_airtraff...5/aim0501.html) that /A (with DME) and /U (without DME) would be correct (assuming no IFR GPS on board).
Same thought ocurred to me on GPS distance readouts as you had Jack...though, like others said, I'm confident it's considered a different animal than DME. Gotta figure that if you're /A, you're legal for an ILS/DME, LOC/DME, etc. approach (one with DME in the approach name), and if you're /U, you're not (and the non-IFR GPS with the mileage readout is just providing SA, not providing any legality for an approach).
Here's the table (which didn't paste well):
Aircraft Suffixes
Suffix Equipment Capability
NO DME
/X No transponder
/T Transponder with no Mode C
/U Transponder with Mode C
DME
/D No transponder
/B Transponder with no Mode C
/A Transponder with Mode C
TACAN ONLY
/M No transponder
/N Transponder with no Mode C
/P Transponder with Mode C
AREA NAVIGATION (RNAV)
/Y LORAN, VOR/DME, or INS with no transponder
/C LORAN, VOR/DME, or INS, transponder with no Mode C
/I LORAN, VOR/DME, or INS, transponder with Mode C
ADVANCED RNAV WITH TRANSPONDER AND MODE C (If an aircraft is
unable to operate with a transponder and/or Mode C, it will revert to
the appropriate code listed above under Area Navigation.)
/E Flight Management System (FMS) with DME/DME and IRU position
updating
/F FMS with DME/DME position updating
/G Global Navigation Satellite System (GNSS), including GPS or Wide Area
Augmentation System (WAAS), with en route and terminal capability.
/R Required Navigational Performance (RNP). The aircraft meets the RNP
type prescribed for the route segment(s), route(s) and/or area
concerned.
Reduced Vertical Separation Minimum (RVSM). Prior to conducting
RVSM operations within the U.S., the operator must obtain
authorization from the FAA or from the responsible authority, as
appropriate.
/J /E with RVSM
/K /F with RVSM
/L /G with RVSM
/Q /R with RVSM
/W RVSM
Bob
