Old 04-12-2009, 02:07 PM
prkaye prkaye is offline
Default union on primer lines
For my longest run of engine primer line, I am thinking of inserting an AN821 elbow at one point to break the line into two sections (one running across the firewall from one side to the other, and the other section then running out from the far side to the cylinder). My thinking is that this will make installation and maintenance easier. My only hesitation is that this extra union will introduce an additional point of failure, and potential point for a fuel leak in the engine compartment. Thoughts?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-12-2009, 04:03 PM
Norman CYYJ Norman CYYJ is offline
yep, but you could mount the union in an adel clamp and make that a support point.
Old 04-14-2009, 08:42 AM
Thanks Normal, that sounds like an excellent idea. That's what I'll do.
Is there a good way to test my fuel primer lines to be sure my connectinos are leak-proof, before hooking them up to the engine?
Phil
RV9A (SB)
Ottawa, Canada
Old 04-14-2009, 08:46 AM
vlittle's Avatar
vlittle vlittle is offline
Does this help?
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 04-14-2009, 02:11 PM
frankh's Avatar
frankh frankh is offline
Default Nice but
Personally I would avoid copper due to potential work hardening.
Frank
Old 07-08-2009, 09:45 AM
ArVeeNiner's Avatar
Default What fittings to use?
Originally Posted by vlittle View Post
Does this help?
Vern
What is the part number of that T in the photo? I bought what I thought were correct from AS but now I'm thinking mine are too big.
As for the copper line, I was going to get some from the local hardware store. So, we're talking 1/8" OD with these?
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
