Old 04-12-2009, 11:39 AM
rv72004 rv72004 is offline
Default Which is the easiest RV to build?
Sounds like a crazy question, but when comparing a 7 to a 8, a tip up to a slider and a TD to a trike , it makes some sense. I was recently helping a friend with a slider do some panel wiring. What a pain. His is a trike so sits level. Now mine is a td with a tip up. If you lie inside and under the panel it is considerably more comfortable as blood goes to your feet.
A 7 TD has the gear on the engine mount. A 8 has those much talked about gear boxes. A tip up is less work. etc etc
Basically we had a discussion the other day and I felt a 7 TD with a tip up is the easiest to build. Some guys seem to think its all much of the same.
For those who have built several models and configurations, what do you say ?
EJ
RV7 flying
xp360, CS, All Glass cockpit
Old 04-12-2009, 01:33 PM
fstringham7a fstringham7a is offline
Default RE:Depends
Hi EJ
It depends.........what? Ya it depends. Each have there challenges. So decide on your and challenge go for it!!!!!!!!
I think the more important question is which one is the most enjoyable to build.......I would say any RV you choose.
Frank @ 1L8 ...RV7A... to the airport soooooooooooooooon!!!!
Old 04-12-2009, 04:09 PM
Norman CYYJ Norman CYYJ is offline
I have built the trikes and the TW the slider and the tip-up. All of them are hard to build or easy to build depending on your level of understanding and experience. Each model presents it's own challenges and frustrations none harder then the other. Build what you want for the mission that you want to fly not on what is easier to do.
Old 04-12-2009, 05:51 PM
GAHco's Avatar
GAHco GAHco is offline
Default The Challenging Parts!
I am building a 6 td. and have been doing so for quite a while.
When people ask me how its going, my answer is always "I'm Making Progress"
I have all of the major aluminum structure built except for the fuselage.
I am painting those parts one at a time and boy am I getting excited!
There are always challenges, and the more complex mentally or physically they are, the more you feel great having accomplished each one of them.
For me the Tanks were the easiest to understand, how they are assembled and sealed all made sense. I have worked as an A&P and IA, and have repaired many tanks like them, but...... I had not built tanks from just materials, it was a long suffering messy, stinky and sticky process with some time limitations.
When I was done, I waited a few months and pressure tested them knowing that a leak even a small one could mean more goo, rivets and temptation to verbally express myself inappropriately.
I manometer tested each one for 2 full days, they only fluctuated with the temperature change in my Garage-mahal (Big Garage) and had no indication of any flaws.
After the test I had a bigger sense of accomplishment than when I drove the last rivet it the last tank. It felt good knowing that task was fully accomplished.
Build the plane you want to have your RV-Grin photo taken in, even if it ends up looking like a shopping cart, it will be your accomplishment and you can be proud of it!
BTW-With your concern for quality, it will not look like a shopping cart
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 04-12-2009, 06:17 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Talking You Guessed it?
The RV-3B because it's the smallest!
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 04-12-2009, 07:05 PM
Mel's Avatar
Mel Mel is offline
Default Which RV is easiest to build?
The one you are most enthused about!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-12-2009, 07:11 PM
RV7AV8R's Avatar
RV7AV8R RV7AV8R is offline
The easiest RV to build is the RV12.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
Old 04-12-2009, 09:07 PM
N941WR's Avatar
N941WR N941WR is offline
Followed by the -10 because the kits and instructions just keep better and better.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
