Tail Lynx Adjustment
Is there an easy way to adjust the length of the Tail Lynx tail spring link? This is in a previously flying aircraft that I am reassembling. They appear too be sloppy loose (not good!). The only way I can make them less sloppy (tight) is to put one link of the assembly on the TOP of the rudder horn, and put the other end on the BOTTOM of the tail wheel arm which effectively lengthens it. I have a picture of how it was when it came off the airplane and it was installed opposite to this. Should it be checked with weight off the tail rod, or does that matter? Thanks and Happy Easter to all.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
