I bought a project that had flop tubes and capacitive senders, but I had float units and wanted to use those with conventional fuel plumbing instead.
Yes, I believe the flop tube will get in the way of the float sender. It's been a while, but I recall taking out the flop tube and capping that exit. Also had to remove part or all of the 'trap door' that is part of the inverted system, as well as removing the brace that serves as a 'guide' for the flop tube.
Roger, 7A, N374RS, Tucson
