Old 04-10-2009, 11:56 AM
mtclay mtclay is offline
Default Annual Condition Inspection Due Date
"No person must operate this aircraft unless within the preceding 12 calendar months it has had a condition inspection performed in accordance with the scope and detail of appendix D to part 43, or other FAA-approved programs, and was found to be in a condition for safe operation. As part of the condition inspection, cockpit instruments must be appropriately marked and needed placards installed in accordance with ? 91.9. In addition, system-essential controls must be in good condition, securely mounted, clearly marked, and provide for ease of operation. This inspection will be recorded in the aircraft maintenance records."
I am slightly confused by the wording of the quote above.
What does "within the preceding 12 calendar months" really mean?
For example, if my last condition inspection was signed off on the 3rd of May do I have until the end of the next May to perform the next inspection, or must it be performed prior to the 3rd of May?
I suspect that I have until the end of May because that's the way the FAA physicals work, but I thought I should ask.
Mike Clay
Orlando, FL
RV-8A N81PD
Old 04-10-2009, 12:01 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by mtclay View Post
...For example, if my last condition inspection was signed off on the 3rd of May do I have until the end of the next May to perform the next inspection, or must it be performed prior to the 3rd of May?
You are correct; you have until the end of May. Either that or complete and sign it June 1st. That way you can creep it around to whenever you want. Of course, you can always do it early as well.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-10-2009, 12:02 PM
Mel's Avatar
Mel Mel is offline
Default Yep!
May is a "calendar month". You have until the end of the month in which last year's inspection was signed Off.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-10-2009, 01:41 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Default If All Is Well
Go the "Free" annual route. If your annual is due in May, fly it all May then start your annual June 1st. The next year, July 1st....and so on. After 12 years you got one free annual and have complied.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 04-10-2009, 01:49 PM
Mel's Avatar
Mel Mel is offline
Been doing this for over 40 years. Works so far!
Hey, I've gotten 3.33 free years.
Old 04-11-2009, 08:21 AM
Thanks Bill, Mel, and Mike.
I was pretty sure I was correct, but figured it wouldn't hurt to ask.
Mike Clay
Orlando, FL
RV-8A N81PD
Old 04-11-2009, 03:00 PM
carguy614's Avatar
carguy614 carguy614 is offline
Default question for Mel
Mel,
can the annual inspection on experimentals be signed off by an A & P, or does it have to be an AI?
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 04-11-2009, 03:06 PM
Mel's Avatar
Mel Mel is offline
Default Any A&P
Originally Posted by carguy614 View Post
Mel,
Chris
can sign off the annual condition inspection. IA is not required.
Old 04-15-2009, 07:54 AM
carguy614's Avatar
Default Thanks!
Thanks a million Mel... I thought that was the way it worked. One of these days I will appear at the FSDO to pick up my RC, but annual time is fast approaching!!
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
RV9 in progress
