Old 04-10-2009, 09:04 AM
celstar's Avatar
celstar celstar is offline
Default Question about fuel transducer
What size ID tubing has everyone used connecting the transducer loop line? Also did you use Steel or Aluminum?
Old 04-10-2009, 09:35 AM
Kevin Horton's Avatar
Fuel pressure transducer or fuel flow transducer?
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 04-10-2009, 09:42 AM
celstar's Avatar
Default Sorry
Fuel flow.
Old 04-10-2009, 10:23 AM
frankh's Avatar
frankh frankh is offline
Default It goes
In the feed line between the boost pump and the firewall..at least it does on the FI system..So its plumbed in the _6 aluminium line using standard AN6 flare fittings.
Frank
Old 04-10-2009, 02:28 PM
I used -6 size Aeroquip aircraft flexible hose covered with firesleeve.
Kevin Horton
RV-8
Moses Lake, WA, USA
Old 04-10-2009, 03:25 PM
chaskuss chaskuss is offline
I suggest you go read JPI's Installation Manual for best location and installation of the fuel flow transducer. See pages 8 & 9 of the manual below.
http://www.jpitech.com/manuals/06/In503ffRevC+Diff.pdf
Charlie Kuss
Old 04-25-2009, 01:54 PM
#N72CR #N72CR is offline
How is fuel flow calulated on an I/O engine.
I'm required to have a return line, and it would appear some fuel would be returned to the tanks, and not actually burned.
I'm installing a Dynon transducer w/ a D-180
Chris
RV-7A
Old 04-25-2009, 03:42 PM
Mel's Avatar
Mel Mel is offline
If you have a return line, you must use 2 transducers, with the "return" transducer subtracting from the "feed" one.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-25-2009, 07:27 PM
rv7charlie rv7charlie is offline
Are you using one of the 'standard' mechanical injection systems for Lycs, with the purge valve return line? If so, you shouldn't need the 2nd transducer. If you're using an automotive type injection system with continuous bypass type mechanical pressure regulator, then dual transducers would be needed.
Charlie
Old 04-25-2009, 07:46 PM
sonny junell's Avatar
sonny junell sonny junell is offline
3/8 OD Soft aluminum, you can get fire sleeve from Mac Master Carr.
http://www.mcmaster.com/#6172t12/=1lt978
with ss clamp
Time, patience, and perseverance overcomes all obstacles.
Our Kit log
www.westernsheetmetal.com
