Old 04-10-2009, 08:12 AM
Cfrisella's Avatar
Cfrisella Cfrisella is offline
Default What did you connect to these?
Currently wiring up my panel. I'm installing dual GRT's, EIS 4000, and Garmin stack( 430,327,SL30 and 240 audio panel. There's a few prewired leads out of the audio panel I haven't found anything abvious to connect them to. They're labled alert sourse 1 2 &3. Do I have a use for these?
Old 04-10-2009, 10:19 AM
vic syracuse vic syracuse is offline
Super Moderator
Typically you can wire these to the audio out of the 330, EFIS, and tru-trak autopilots. That way you will get audio traffic alerts, altitude alerts, and other warnings.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
