Dynon magnetometer & Whelen Strobe
Does anyone have any experience regarding mounting the Dynon magnetometer and a Whelen strobe power supply in relatively close proximity to each other? I need to mount them both in my right wing tip and wondered what problems this will create. The Whelen installation is temporary....within a couple of months it will come out and Aveo Engineering LED based strobes and nav lights will be going in. I knew going in that I'd be using the Aveo products so was not worried about the magnetometer being in the same tip as the LED's, but Aveo has been a little slow with delivery. They are supposed to show their embedded wing tip lights at S n F. Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
