Old 04-09-2009, 12:34 PM
sonny junell's Avatar
sonny junell sonny junell is offline
Default Panel Mount Zaon XRX
Have any of you turned your XRX into a panel mount? Either by some how in-setting the complete unit into the dash ??. or by removing the antenna, moving it externally and then flush mount the control unit in the panel and wiring it to your favorite MFD. ,
I guess worst case Scenario (not that bad) is building a low profile permanent enclosure on top the dash.
I am looking at skywatch @ $$$ and the Zaon unit @ $. Nothing you don't know.
Any helpful commentary would be appreciated
Time, patience, and perseverance overcomes all obstacles.
Our Kit log
www.westernsheetmetal.com
Old 04-09-2009, 12:39 PM
Phil's Avatar
Phil Phil is offline
Never thought about flush mounting an XRX....
I was planning on a Mode-S transponder and displaying the data on the EFIS....
Old 04-09-2009, 12:50 PM
Bro I was kicking that idea around as well,
the only caveat I can come to for that is for some reason the FAA is disabling the TIS system in certain markets or centers, WTF?
I believe this is due to ADS-B?. ??? With that said quite a few mountain airports that we fly too, do not have the TIS available.
Our Kit log
Old 04-09-2009, 12:54 PM
Jamie's Avatar
Jamie Jamie is offline
The Zaon units have nothing to do with TIS. They only work off of transponder replies to radar interrogations of your transponder. TIS is actual data relayed to your transponder that then gets displayed on an MFD/GPS/EFIS, etc.
Old 04-09-2009, 01:10 PM
Correct! However the FAA is/will be disabling TIS or MODE S data link, service from tracon.
Back to the burning question, any one panel mounted this XRX?
Our Kit log
Old 04-09-2009, 01:19 PM
the_other_dougreeves the_other_dougreeves is offline
I looked at it - they have a panel mount bracket. It shouldn't be hard, but I want to be able to use the XRX in the CT or the glider, so I abandoned the panel-mount idea.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 04-09-2009, 04:06 PM
tommylewis's Avatar
tommylewis tommylewis is offline
Default XRX mount
While I did not mount the XRX in the panel, I did mount it in the baggage area and it does appear to work okay. Installed before our trip to Az, Cheyenne, Wy and South Dakota. Not alot of traffic in some of those areas, but last weekend our EAA chapter had a poker run with 23 airplanes and we had lots of targets to track.
I have it connected to a GRT efis for the traffic display.
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 04-09-2009, 04:45 PM
49clipper 49clipper is offline
Default 49clipper
I wonder if that could be connected to a Lowrance gps?
Old 04-09-2009, 08:20 PM
Thanks for the PIC, and the XRX just comes on with power? I guess? Or is that a pre-flight item to turn it on?
Our Kit log
Old 04-09-2009, 08:50 PM
tommylewis's Avatar
Default Zaon XRX
The XRX has a factory modification so that it turns on when power is applied. You need to RMA it back to Zaon for I think $20 to get that option. I have not done it yet, but intend to after Sun n Fun. Currently, the pilot can reach the power button and the ack button to start it up, then the GRT displays any traffic. GRT displays S mode traffic from a 330 and XRX traffic the same way as follows:
Now this picture was taken in my hangar with the pressure altitude on the XRX cranked up to 10000 feet so I could "see" traffic coming from Glen Rose VOR into DFW.
One of the nice features of an experimental airplane is that I can try this approach to get traffic into my panel.
Tom Lewis
Granbury, Tx
