Old 04-08-2009, 05:25 PM
Inverted Inverted is offline
Default Thoughts on this air compressor?
I am considering purchasing the following air compressor to build(and hopefully paint) my rv with. I'd like something that doesn't turn on all that frequently. Any suggestions, hints, tips, mockery is appreciated.
http://www2.northerntool.com/air-com...em-1592027.htm
Old 04-08-2009, 05:45 PM
rleffler's Avatar
rleffler rleffler is offline
Looks ok. I got mine at Home Depot with similiar specs for about $200 less.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 04-08-2009, 06:04 PM
Thumbs up
This is very good one. Will serve you long. Wheels would be a great plus.
Old 04-08-2009, 06:09 PM
fstringham7a fstringham7a is offline
Default RE:Air quality
Hi
I looked at that compressor but went with a Campbell Hausfeld 80 gal/16 CFM @ 90 PSI ($750 at Lowes aero)for the paint type I was shooting.
The big thing when painting is clean air... not to forget mentioning clean spray space / clean parts to paint. In regards to clean air for painting get a very good oil/water seperator and regulator to protect the air at the paint gun. Don't go with the cheap stuff like you see in the above picture.
Good luck in your build......
Frank @ 1L8 ....RV7A...
SMO's Avatar
SMO SMO is offline
Default Two Stage
If you want something that keeps up with your rotary tools you will probably want a two stage compressor. I had one similar to what you are looking at and was not at all happy. It wouldnt keep up with my Blue Point die grinder and had trouble keeping up with the bigger paint jobs.
The larger the tank and the higher the pressure it maintains the less often it comes on.
I bought one from a service station that shut down and couldn't be happier. It is an old clunker, 80 gallon tank, two stage, cycles between 120 and 150 psi and keeps up with everything I have. If you can find a two stage used you will pay the same money as the one you are looking at (or a little more) but you will be much happier with it.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 04-08-2009, 06:12 PM
zzapp zzapp is offline
Default Go with it.
I wish I bought the IR. Mine is a 5hp from Lowe's ( made in USA supposedly ) and has had more than it's share of problems. The free shipping completes the deal.
Old 04-08-2009, 07:05 PM
flytoboat's Avatar
flytoboat flytoboat is offline
Default compressor
That's the one I have. No regrets and would do the same again.
Good Luck.
Don
VAF #1100, EAA864
-6A bought flying
Old 04-08-2009, 07:30 PM
PCHunt PCHunt is offline
Default Ditto
I have the exact same model, and love it. Haven't painted with it, however. Runs nice and relatively quiet.
Their warranty is good, also. My original one had a very tiny pinhole in a weld seam on the tank. I kept losing pressure slowly, and tried every fitting to no avail. Then one day my son came to the hangar, and said, "Hey Dad, what's that high-pitch squeal I keep hearing?" Of course, I couldn't hear it!
Within seconds, he had located the weld defect, and IR replaced the entire machine, no question. Apparently a defect in the pressure vessel (tank) is a BIG deal to manufacturers.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 04-08-2009, 08:27 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Thumbs up
I bought the same one from Northern tools. It served me well for building one plane and plan to keep using it if I build another.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
