04-08-2009, 03:24 PM
Odyssey PC-680 Alternatives?
I realize that by asking the question, I am committing heresy!
Anyone have experience with PowerSonic PS-12180, or any other similar battery? When you look at the specs, they are similar. And at $44.00, if it's even close, one could save $$.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
04-08-2009, 04:20 PM
I am using a Panasonic 12V-20AH battery bought from DigiKey. First one lasted 4 years. It was getting weak and I replaced it this year with another on just like it.
Tommy Walker
RV-6A, N 350 TW
402 hours
04-08-2009, 05:25 PM
been here awhile
Here ya go, Pete:
http://home.hiwaay.net/~sbuc/journal/battery.htm
04-08-2009, 07:48 PM
Panasonic LC X1220P
I had 2 of these batteries in my RV-8 for over 5 years.
I replaced them with new ones so I could use the 2 old ones to install in my
RV-10 project.
The originals were less than 30 dollars, however the price is now around $60.-
Everyone around here uses them with good results.
Save your money for gas.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
04-08-2009, 09:38 PM
PC680 Clone
This looks interesting, too. It has screw terminals like the PC680.... but a bit more $$.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
04-08-2009, 10:19 PM
The tempest looks tempting
Does anyone know if it will fit the odyssey mount? Anyone have experience with it?
Edit:
A quick google search found this link:
http://www.lotustalk.com/forums/f129...-better-62396/
http://www.tempestbatteries.com/html/bab22-12.html
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
04-09-2009, 07:20 AM
Check out the PSH-12180
If you're interested in trying a Power-Sonic battery, you might consider the PSH-12180. It has the same case as the PS-12180, but is designed specifically for high-rate discharge applications and has a higher 21.0 amp-hour capacity rating. It comes standard with a nut-and-bolt terminals.
Dave Cole RV-7 N97DC reserved
dave.cole@cox.net
Started SB April 2004
Hope to fly in 2011
04-09-2009, 07:52 AM
I've been using PowerSonic batteries in my -6 for over 16 years. They typically last between 4 & 6 years. Since they are sealed lead acid, they are not picky about charge rates.
Never had one go out without plenty of warning.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
04-21-2009, 11:57 AM
Mel, is this the battery you're using?
http://www.gotbatteries.com/items.as...all/PS-12180NB
The dimensions look to be very close to the PC680. Does it fit in the same mount? AN4 hardware to attach it to the battery cables?
Thanks!
