Originally Posted by vonjet
The problem is that one of my comm antennas is not accessible anymore.
Totally inaccessible? Then you should slap whoever built it upside the haid.
Seriously though, what if you unscrew the base of the antenna from the outside? Can you get access to the cable end that way?
Personally I think replacing RG-58 with RG-400 is worth it if you can do it for the whole run. Not so much for less loss than RG-58, but for better shielding and for better handling (pulling teflon jacketed cable vs PVC cable through a full conduit... no contest).
But in your case if you have a particular problem that you think might be bad shielding, I would try clamp on ferrite cores first... that's pretty easy to do.
--Paul
