Tip: Ordering Vernier Control Cable Lengths
I ran into an "interesting situation" regarding Vernier control cable lengths....
The Throttle, Mixture, Prop cables that come with the FWF kit are based on Van's prototype layout.
But there are numerous variables that will affect the builder;
Carb Vs FI,
Vertical Vs Horiz induction,
Panel or Sub-Panel mounted.
In my case, the Mixture was WAY too short and Throttle WAY too long... but the prop was just right. Hummm.... sounds like a bed time story I once heard.....
Van's carries various lengths of cables and are listed in the Accessories Catalog. I was able to trade the Throttle cable for shorter and it works fine.
But the Mixture is a problem. Because I mounted my Mixture in the Panel instead of the dropped down Sub-Panel and mounted it further to the right than Van's, I need AT LEAST 55". Van's longest cable is 51.5".
So I ordered an A-1760 style, 60" Mixture cable from Aircraft Spruce. When I tried to install it, the "working end" was WAY TO LONG!!!!! I called Van's and ACS Products in Lake Havasu, NV (who makes the cables for Van's AND A.S.) Turns out, Van's working end lengths are NOT standard cable lengths, but are several inches shorter. Van's will not special order from ACS Products, but A.S. will.
The key is, you have to tell A.S. the cable is for a Van's aircraft so that ACS Products knows to make the working end according to Van's lengths.
A Special Order doubles the price of the cable and is non-returnable. So be careful when you do your layouts so you know what you're getting into.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
